Joel77
  • en réponse à : Mon expérience : FIREFOX a disparu de mon Système [RESOLU] #92007
    Joel77
    Bonjour Fernand, merci pour votre retour
    Mon Portable est un Asus K756U, Intel I7 -6500, Ram 8Go, DD 1Go, W10 famille 64 - 22h2
    Je joins le rapport de GFXplorer
    Report generated by GFXplorer 3.9.9.1380 made by Xtreme-LAb - https://www.xtreme-lab.net/
    Operating System:
    Name: Microsoft Windows 10 Famille
    Version: Insider preview (19H1)
    Version Number: 10.0.19045.4957
    System Build type: Multiprocessor Free
    System type: 64 bit
    System Memory:
    Paging File\s:
    No Paging file or automatically managed
    Free physical memory: 3,14 GB
    Usable physical memory: 7,90 GB
    Free virtual memory: 2,15 GB
    Usable virtual memory: 9,15 GB
    System Applications:
    .Net Framework version\s: 4.7.2+
    Installed DirectX version: 12.0 (10.0.19041.4522)
    System Folders:
    Windows® folder location: C:\WINDOWS
    Program files folder location: C:\Program Files
    System folder location: C:\WINDOWS\system32
    Central Processing Unit (CPU):
    Manufacturer (signature): Intel® Corporation (GenuineIntel)
    Model: Intel® Core™ i7-6500U @ 2.50GHz
    Specifications: Intel64 Family 6 Model 78 Stepping 3
    Clock speed (current \ base): 2492 MHz \ 2592 MHz
    Socket type: U3E1
    Cache Memory: L1 64KB, L2 64KB, L3 512KB, L4 4096KB
    Number of cores (physical \ logical): 2 \ 4
    RAM bank\s:
    BANK 0 \ 2133 MHZ \ 4 096 MB \ SODIMM
    BANK 2 \ 2133 MHZ \ 4 096 MB \ SODIMM
    Total RAM installed: 8 192 MB
    Motherboard and BIOS:
    Motherboard manufacturer: ASUSTeK COMPUTER INC.
    Motherboard model: X756UXM
    BIOS manufacturer: American Megatrends Inc.
    BIOS version: 3.0 - X756UXM.203
    BIOS release date: 04/19/2019
    Graphics Processing Unit\s (GPU):
    NVIDIA GeForce GTX 950M (2048 MB)
    Intel(R) HD Graphics 520 (1024 MB)
    Audio adapter\s:
    Son Intel(R) pour écrans
    Conexant SmartAudio HD
    NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
    Monitor\s:
    DISPLAY1 - 1600x900 @ 32bpp (Primary)
    Drives and Partitions:
    C:\ - ( GodMode.{ED7BA470-8E54-465E-825)
    File System: NTFS
    Total capacity: 152 678,57 MB
    Free space: 88 487,50 MB
    E:\ - (DATA)
    File System: NTFS
    Total capacity: 799 999,00 MB
    Free space: 205 750,52 MB
    F:\ - (TOSHIBA EXT)
    File System: NTFS
    Total capacity: 953 867,00 MB
    Free space: 216 438,51 MB
    Storage devices (HDD, SSD and USB):
    HGST HTS541010A9E680 - PHYSICALDRIVE0
    Firmware version: JA0OA560
    Number of partitions: 5
    Drive capacity: 953 867,22 MB (1 TB)
    Technical information: 512 bytes per sector, 1953520065 sectors, 63 sectors per track, 31008255 tracks, 255 tracks per cylinder, 121601 cylinders.
    TOSHIBA External USB 3.0 USB Device - PHYSICALDRIVE1
    Firmware version: 5438
    Number of partitions: 1
    End of report.
    Merci d'avance pour votre aide
    Joel
    • Cette réponse a été modifiée le il y a 10 mois et 2 semaines par Avatar photoMAB.
    en réponse à : Mon expérience : FIREFOX a disparu de mon Système [RESOLU] #92000
    Joel77
    Bonjour Fernand
    J'ai essayé d'installer des logiciels comme sfc /scannow ou d'autres pour controler mon système W10 family 64, mais impossible d'intégrer des logiciels proposés par SOSPC comme GFX explorer, XD Antispy...
    Tout logiciel extérieur n'est pas installable car non MS... Donc il y a des blocages qui sont difficilement supportables !
    Merci de me conseillé une suite pour être libre de choisir mes logiciels et outils complémentaires...
    Cordialement Joel ops
    en réponse à : Mon expérience : FIREFOX a disparu de mon Système [RESOLU] #91854
    Joel77
    Bonjour à tous et merci pour vos retours
    Mon Portable est un Asus K756U, Intel I7 -6500, RAM8Go, DD 1Go, W10 famille 64 - 22h2
    Fidèle à Mozilla Thunderbird et Firefox depuis <10ans
    Logiciels : Avast One,  Libre Office, VLC, Filezilla, BlueGriffon
    Nettoyages très souvent avec : Glary, Emjysoft Cleaner, HDCleaner
    J'ai testé W11 sur un autre Pc et je le trouve moins bien que W10...
    Mon Pc ne le supporte pas à cause du processor + pas de TMP!
    Pourquoi supprimer mon Firefox avec recherche Google ??
    Il est vrai que j'ai viré Bing, il y a quelques mois !
    A mon avis l'exclusion de mon Firefox est dû à l'installation tardive de la MàJ 22H2...
    Pour l'instant, ça remarche normalement. Bon voila, vous savez presque tout...
    Merci pour tout, cordialement Joel Mh
    en réponse à : Mon expérience : FIREFOX a disparu de mon Système [RESOLU] #91802
    Joel77
    Bonjour Azamos & Privet, merci pour vos messages
    Il faut que je précise que j'ai choisi Google comme outil de recherche, car celui de MS ne me donnait pas satisfaction...
    La semaine dernière, suite à la fin de ma mise à jour de W10 vers 22H2, cela a peut être déclencher la perte de Firefox carrément, mais plus aucune trace même dans le panneau de config ?
    Cela sent pas très bon pour la suite de W10...
    Merci pour tout
    @+Joel77
